TV hub channels missing frequently since new
Tim011
Message 7 of 7
I have recently ordered the new TV hub box (with no recording facility), having set up the box ok
and tuned in  over 200 channels on Freeview with the aerial connected directly to the Hub after 3 days the box seemed to loose most of the channels, while some remained. I moved the aerial from the TV hub to the TV directly and all 200 channels were there. I read some online tips and retuned the TV hub, all channels were restored and again it was ok for a few days until the same problem happened again, needing the TV hub to be retuned, again all channels were restored. This is happening too frequently now, almost every day the hub needs retuning, even powering the Hub down/up does not restore the channels and I have checked the signal levels on our LG tv and all are 100% signal strength and signal quality, so I'm thinking there is a fault with the TV hub loosing the channels frequently. When we had the old TalkTalk TV box we never had any problem with the signal and never lost any channels, this has happened only since installing the new TV Hub. Could you please advise how to fix this annoying problem.
Yours sincerely
6 REPLIES 6
Message 1 of 7
Totally agree, a new Hub is what's needed, that would have been my next step.
Let me know if things are ok with the new Hub.
Message 2 of 7
Hi Karl,
We lost channels again, today the TV Hub shows just 38 channels where as after each time I retune the hub it recovers with 179 channels.
I managed to call TT support, and was on the call for over 2 hours, while the rep was very patient and understanding I felt the issue was not being resolved. Eventually I was passed through to the manager who suggested to send an engineer round, I said that they won't fix it it needs a new hub...thankfully they agreed and a new TV hub is on its way to me. Fingers crossed this one will work.
Message 3 of 7
Glad to hear the channels have been restored.  Keep an eye on things and let me know asap if this happens again.
Message 4 of 7
hello,
yes, I followed the instructions exactly for the reset, and again 179 channels were received ok when at the tuning process, but again after some hours the hub showed most of the channels from 1-to-100 were missing, while those on HD were all there. But then later in the day the hub reported there was no signal at all, even though the YouView guide showed all program details for all channels we could not select any channel, so to test the signal I again moved the aerial from the hub to the LG TV showed all channels were received in perfect quality.
Having tried yesterday to chat online to TT they could not help as systems were down, but my internet is working fine.
So today I got through on the phone to a TT rep in South Africa, who again went through some checks with me, this time asked me to use the reset button on the back of the hub (needed a pin), and this time channels were restored and this  evening are all still viewable.
My thoughts are though the new TV hub has an intermittent fault. The TT TV box with recorder we had for many years was faultless,
Message 5 of 7
Hi Tim011
Did you try the reset as advised ?
Message 6 of 7
Have you tried resetting the box to see if there was a bug in the software?
Details on how to do this can be found here:
https://community.talktalk.co.uk/t5/Articles/TV-Box-Maintenance-Reset/ta-p/1429347
Let us know how you get on.
