Wi-fi dropout
Woodpecker63
Message 14 of 14
Almost every evening around 5:00 our wi-fi drops out for a few hours. Only two of us in the house and mostly only one using the system. Not a major issue but irritating at times when we want to check for emails or read TV Times or look at Facebook etc. I understand that network congestion or throttling are the probable causes but is there a possible cure?
Richard
13 REPLIES 13
Message 1 of 14
I'm really glad to hear this and please let us know if you need any further assistance.
Michelle 🙂
Woodpecker63
Message 2 of 14
Hi, I have been slow to respond whilst following progress. I am pleased to note that we-fi has been working well for the week to date.  I thank you and colleagues for whatever you did to fix the problem. I am sure that I did nothing myself to improve the situation. I thank you dearly and hope that I do not have to bother you further
Richard
Message 3 of 14
OK thanks. And as far as you are aware all device lose their internet connection at the same time?
Woodpecker63
Message 4 of 14
We are an elderly couple and not technically knowledgeable so answering tour questions is not easy.
You say "Are all your devices connected to the router by wifi or do you have devices connected by Ethernet cable?"
My best reply is attached to the router are: 1)Mains line, 2)phone line, 3)Grey cable to BT Mini Wi Fi Hobspot mains connector that leads to downstairs connector to TV, 4)Yellow cable to TalkTalk mains that also leads to downstairs mains input to Manhattan TV box plus, 5) Yellow cable to PC.
The wifi failure is quite recently regular.  Always at approximately the same evening times.
Richard
Message 5 of 14
Woodpecker63
Message 6 of 14
I'm not aware of any specific change to router lighting when the wi-fi drops out but I can check specifically when it occurs next (probably this evening). The router power and broadband lights are constant. The internet, wireless and ethernet lights flash all the time and the tv light doesn't light at all.
Richard
Message 7 of 14
Hi Woodpecker63,
Line test isn't showing any disconnections. Does the light change on your router when the connection drops?
Woodpecker63
Message 8 of 14
All connections at home are fine, we just get the loss of wi.fi connection at evening time. It is not every day, but most, with no regularity in times.
Richard
Message 9 of 14
Hi Woodpecker63
Thanks for checking this. I've also completed a line test which hasn't detected any faults.
Are wired connections ok? Once we have confirmed this then we can focus on the wireless performance.
Woodpecker63
Message 10 of 14
I can confirm that I have checked HomeSafe and am assured that the KidSafe bit has not been signed on, nor has anything else. Is there anything else that can be done to avoid my wi-fi dropouts?
Richard
Message 11 of 14
Hi Woodpecker63
So every TalkTalk broadband customer gets our HomeSafe web filter included for their home Wi-Fi, protecting any device that’s connected. You just activate it and choose your settings in My Account.
How to use HomeSafe® - TalkTalk Help & Support
Woodpecker63
Message 12 of 14
Sorry, I don't understand. How do I "log into My Account and check to see if HomeSafe/KidsSafe has been switched on?
I have never knowingly switched any such matter.
Richard
Message 13 of 14
Hi Woodpecker63
Can you log into My Account and check to see if HomeSafe/KidsSafe has been switched on?
