Caller Display lets you see who's calling before you pick up the phone. The caller's number will appear on your phone's display screen, so you can choose to pick it up or let it go to your answering service.
You can also use Caller Display to avoid nuisance or cold calls. If your phone doesn't have a display screen, it can't be used with this feature.
Here are some reasons Caller Display might not work:
Withheld numbers - if the caller has withheld their number it won't appear in your display. Try calling from a number you know isn’t withheld to see if this remedies the problem.
Faulty display screens - try using a different phone with a display screen. If Caller Display works on this phone then it’s likely there’s a problem with the first one.
Interference - sometimes faulty equipment or devices can interfere with Caller Display.
Try the following:
If reconnecting a device stops Caller Display from working, that's the one that’s causing the interference. Try not to use it while you use Caller Display.
Want to know how much this and other calling features cost? Read our article How much do calling features cost?
