Email settings to access TalkTalk emails
There are two ways you can access your TalkTalk emails, via webmail which is  located at apps.talktalk.co.uk or via a client/app on your smart device such as a phone or tablet and your computer. You'll need your email address and password to access webmail. If setting up a client/app, you'll also need the following settings.
Before changing your settings, we recommend that you back up your email data files on your device. For more information on how to do this check with your software/app provider's instructions. Our recommendation is to use IMAP rather than POP3 settings, as this will ensure a copy of your emails is retained on our Mail server, as well as on your local device.
This table shows the correct email settings to use when setting up your talktalk email on your device and email client
Setting Value to use
Incoming Mail Settings
Incoming mail server mail.talktalk.net
Use SSL (for Apple iOS) Set to ON (Green)
Security Type (for Android) SSL/TLS or SSL
Encryption Method (for Windows/Mac Mail SSL/TLS
Server Port (alldevices if using IMAP) 993
Server Port (all devices if using POP3) 995
Outgoing Mail Settings
Outgoing mail server smtp.talktalk.net
Use SSL for Apple iOS) Set to On (Green)
Security Type (for Android) STARTTLS  or TLS
Encryption Method (for Windows) STARTTLS
Server Port (all devices) 587
setting up or changing your email on your devices
We've created operating system-specific guides for the most popular brands of devices and mail clients/apps used by our customers. For step-by-step instructions for anything not listed below, refer to your device's original setup guide or ask the community for help who's online 24/7, 365 days a year:
apple
Guide to help you set up or check email on an Apple iPhone, iPad or iPod, we recommend updating to the latest software.
android
Guide to help you set up or check email on an Android phone or tablet, we recommend updating to the latest software.
windows mail
Guide to help you set up or check mail on your Windows device, using Outlook or Windows Mail.
mac mail
Guide to help you set up or check  mail on your Apple Mac device. Using the apple mail client, Mac Mail.
Device not listed above?
If you can’t find what you’re looking for, why not post a question on our community. Here to help 24/7, 365 days a year.
You never know, the answer, may already be waiting for you.
MD5 email authentication
We no longer support Legacy MD5 authentication. However, we do have strong measures in place such as SSL/TLS.
