Reset TalkTalk TV box to factory settings
No ratings
Resetting your TalkTalk TV Box to factory settings can help fix some issues.
If you complete the reset, you’ll lose any programmes you have recorded, any scheduled recordings and any personal settings. This is why we only recommend it as a last resort.
If your box has frozen and requires a restart, you can perform a simple power down by either turning it off at the mains or using the power button at the back of the box.
You can reset your TalkTalk TV Box to factory settings by following the below steps:
  1. Press the Menu / youview button
  2. Select Settings
  3. Select Factory Reset
  4. Select Reset
After you’ve reset your box to factory settings, you’ll need to complete the setup wizard by following the onscreen steps.
Mike
Hi, I’m Mike did you find my article useful?
Looking for help ?
We have a reduced support team available at the moment, which means the wait times to speak to us may be longer than usual. Why not manage your account or get help with your services online using one of the below options
