on 27-09-2022 10:12 AM
For the last year my broadband has been completely fine, as fast as it can be in my area.
But the last couple of weeks the internet has been so slow, and I've had to restart the router a bunch of times because all my devices were saying "Connected (No internet)".
Then today I had to try couple of times to login to my account because the first times it would throw a server error.
Is there anything going on?
on 30-09-2022 02:36 PM
Hi superbcar,
I can see that Keith has kindly offered to help you with this, how are your getting on?
on 27-09-2022 01:06 PM
I can help a lot with this, but there are no set speed test values for WiFi connections. This is because so much depends on the specifications of your wifi network adapter and the level of WiFi interference.
Slow speed, intermittent dropouts, breaks in the signal, no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
If you would like me to help you, please can you specify the make/model of TalkTalk router that you are using?
on 27-09-2022 12:16 PM
No the 2.4GHz is even slower, was getting like 13Mbps on that one.
on 27-09-2022 12:09 PM
The bottom of the upstream range is 7Mbps although upstream speeds aren't guaranteed
So just to confirm, you only experience the slow speeds on device connected to the 5GHz band? The 2.4GHz band is OK?
on 27-09-2022 11:40 AM
On Wifi, 5GHz.
Do you know what the average upload speed is supposed to be?
on 27-09-2022 10:25 AM
Hi superbcar,
Line test is passing, your connection looks stable and your router is in sync at 38.3Mbps. Are you experiencing the slow speeds on devices connected to your router by Ethernet cable or wifi?
