on 31-08-2025 07:02 PM
Its years old .i think they are now obsolete , what can i buy to replace it ?
It plugs into my router via a ethernet cable and sends a signal to another same one thats connected to my TV .
on 01-09-2025 08:54 AM
on 31-08-2025 07:10 PM
TalkTalk no longer supply powerline extenders, but you can search third-party sites for a suitable replacement.
Alternatively, depending on your router, you can buy a WiFi booster from TalkTalk. Get in touch with customer services directly when they are open again tomorrow, or wait for further advice from the support team here.
on 31-08-2025 07:05 PM
You can buy powerline plugs from Currys, Amazon etc. in packs of 2 so they should link out of the box.
