Plex, uTorrent and Robot Lawnmower Problems
Leonbamford
Message 2 of 2
I am currently unable to have a direct connection to my Plex server. This was ok in the past, I'm not sure when it stopped working, but no changes have been made on the server side. I have also noticed that uTorrent cannot be accessed remotely either, despite it being set in the port forwarding rules. Again, this worked fine in the past.
I also cannot connect my new robot lawnmower to my home network. The device scans for a WiFi signal, but never finds it. I've had a replacement device, and that does the same thing.
I've got a feeling that these issues might be all be related to the router.
1 REPLY 1
Message 1 of 2
2. If you have any wired connections, are they affected in the same way as wireless ones?
