VPN connection no longer working
craig-bear
Message 4 of 4
I used to be able to connect from home to my work VPN but this has recently stopped working. It still works from a different network not at my home.
My work IT department have asked me to tell you that your broadband seems to be blocking access to a VPN. The VPN Type I am trying to access is PPTP with additional protocols CHAP and MS-CHAP v2.
My router is a TalkTalk Wifi Hub version FAST 5364-3.T8
Please help.
3 REPLIES 3
Message 1 of 4
Hi craig-bear
Apologies for this.
I have ordered you a different make and model of router, please allow 24-48hrs for this to arrive.
craig-bear
Message 2 of 4
Hi @Skynet_TX
Indeed the router dashboard screen does show SG4K100130 as the version.
How do I request the different type of router?
Skynet_TX
Message 3 of 4
Hi @craig-bear,
If you browse to the router login screen at http://192.168.1.1/ does the 'version' at the bottom of the screen show : SG4K100130
If so, then this is a new version of firmware, and several customers have been having VPN access issues with this firmware. Staff here may just suggest sending you a new router of a different type.
