on 13-09-2023 09:51 AM
I have talktalk wifihub and wifibooster. when the internet speed was epileptic and slow, I reset both wifihub and wifibooster to factory setting. after the reset, my wifibooster is being experiencing difficult to connect with wifihub.
Please what can I do to reconnect the wifibooster with wifihub?
on 13-09-2023 11:02 AM
Please can you be more exact, is this the Sagemcom 5364 hub & Sagemcom 266 WiFi Booster?
Assuming that it is, have you got WPS still enabled in the router on both bands? When you try & connect the 266 via WPS, you first need to wait for the 5364 to be up & running OK. Then when trying to connect via WPS, what is the exact status of the lights on the 266 at that time?
