Home Phone
Digital voice app
sjbvw
Message 7 of 7
How do I find my old password as I need to enter it before I can select new password?
6 REPLIES 6
Philile-TT
Message 1 of 7
@sjbvw please contact the full fibre team using the contact details below:
Contact Number: 03451720074
Opening Hours:
VOICE - Mon-Fri: 9am-7pm; Sat: 9am-6pm; Sun: closed
Phili
Message 2 of 7
Hi @sjbvw exhausted my suggestions, good news is the professionals are in tomorrow. I'm sure they will help you out.
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
Message 3 of 7
I did
Message 4 of 7
Did you check in junk?
Message 5 of 7
Hi @Divsec
I have tried that option where it says there will be an email sent with a link, that didn’t arrive.
Divsec
Message 6 of 7
Hi @sjbvw this is a slightly risky solution! Log out of the app you are in then try to login in again most apps I use give a forgotten password option.
