sound volume at max and not syncronised with picture
dmac415
Message 2 of 2
The sound on the tv hub is at maximum and tv sound very high. The sound and picture are not synchronised.
1 REPLY 1
Message 1 of 2
If you go to settings there is a setting under sound that allows you to adjust the sound to sync.
