on 03-12-2025 01:33 PM
I'd like to add a UPS into my setup to avoid wifi being down during power cuts. The UPS I'm looking at has the 12v output rated as up to 3A, am I ok to use this for a TalkTalk Sagemcom dual band hub ? The mains adapter that came with the hub is rated as 12v / 1.5A
The UPS comes with automatic voltage regulation etc to avoid overcharges.
Cheers,
Mick
08-12-2025 07:02 AM - edited 08-12-2025 07:03 AM
Hi there @MickL, thank you for getting back to us. I'm sure @KeithFrench has seen the thread, you are most welcome. Bye for now, I'm sure you know where to find us should need help with anything. Thanks
on 05-12-2025 06:46 PM
Hi Keith, no problem and thanks for your time. I'll probably buy an inexpensive spare router (I wanted a backup device anyway) and experiment with that.
Cheers,
Mick
on 05-12-2025 11:26 AM
Hi there @KeithFrench, thank you very much for the help.
on 05-12-2025 11:21 AM
I am sorry, but I can't recommend using what is essentially a non-standard power supply for your router; you are on your own with this.
on 05-12-2025 07:01 AM
@KeithFrench please assist.
on 04-12-2025 05:02 PM
Thanks Keith, I hear what you're saying and agree that an AC supply would be safest but sadly my budget doesn't run to a UPS that will give a few hours of AC power. I'm comfortable with a DC UPS, just need to confirm polarity compatibility with the hub...the UPS I'm looking at has the centre contact +ve and the outer collar -ve. The 12v output is rated up to 3A, and the total power output from the UPS (across all sockets) is 35W. I think I'm ok with this, provided the plug fits ! It comes with 5.5x2.5, 5.5x2.1 and 5.5x1.9 plugs.
on 03-12-2025 03:00 PM
Thank you @KeithFrench, muchly appreciated.
on 03-12-2025 02:58 PM
Hi @MickL
With that type of UPS with a 12V DC connection, it is more complex to make the correct choice. It is much simpler to choose the type that has UK mains power outlets on it. The first thing is the power connector; without a micrometre, it is difficult to know the size. This article does inform how to measure it:-
Then the polarity must be considered, get that wrong & you will probably permanently damage the router.
It is far easier & safer to go down the route of a UPS with UK power outlets on it. If you have full fibre, then you would also need to connect the ONT to it, as well as the base station of any DECT phone system & possibly a Grandstream DVA (OK, I know the latter two are not Wi-Fi). Perhaps you would also need to add a PC or other mains-powered devices to the list.
What you buy would be down to you, as only you know how long you want the internal batteries in the UPS to last during a power cut. This is often specified in the unit's VA rating.
on 03-12-2025 01:57 PM
Hi there Mick, please note we don't provide UPS, so I won't have much information on that. allow me to ask @KeithFrench if he has any information on this.
