5ghz channel disappeared
CMJTW
Message 10 of 10
I have been having internet problems for a number of days. The initial problem was at the local exchange which has now been rectified following a visit by Openreach.
I now have a problem with my router in that the 5ghz band cannot be found by any of my devices. I have changed the channel to Auto from 36 but the network is still not visible.
9 REPLIES 9
Message 1 of 10
I'm glad to hear this and thanks for confirming 🙂
CMJTW
Message 2 of 10
I did a Ferranti reset and it is now working
Message 3 of 10
How are you getting on?
Message 4 of 10
Thank you. I am currently in the middle of watching the replay of the qualifying of the Japanese Grand Prix so I will do it tonight.
Message 5 of 10
S I said it does not matter if it is the 5364 or the 5464, they are both affected by this bug.
CMJTW
Message 6 of 10
FAST 5364 AC1200 Dual-Band Wi-FI Router
Message 7 of 10
OK, it doesn't matter which one, the 5364 or the 5464. There is a bug in firmware V174 that if a WiFi band is disabled & later re-enabled, it does not come back as it should. Until the next firmware version becomes available, the only workaround is to do a factory reset in the router's configuration. Please do this & see if that sorts the problem.
CMJTW
Message 8 of 10
It is a Sagecom
Message 9 of 10
What make/model of router are you using?
