Broadband Speed
Pnokio
Whizz Kid
Message 10 of 10
Why is my speed so low?
George
9 REPLIES 9
Message 1 of 10
Great thanks for confirming 🙂
Pnokio
Whizz Kid
Message 2 of 10
No thanks, AllyM did all I needed.
George
Message 3 of 10
How are you getting on? Do you still need any assistance with this?
Pnokio
Whizz Kid
Message 4 of 10
Thanks AllyM it now nearly bac to where it should be.
George
AllyM
Message 5 of 10
Ok, last posts crossed over.
So I'm guessing your current sync speed 38Mbps is normal for your line?
If sync speed is ok but throughput is low (both wired and wireless) then it may be worthwhile switching off the router for 30 minutes.
If wired speeds are ok, that would suggest a WiFi issue which would need further investigation.
AllyM
Message 6 of 10
Just log into the router admin and go to the connection stats page.
If sync speed is also low, then there could be an issue with the external line or any internal wiring in your house. In which case try connecting to the master socket "test" socket, check for any noise on the landline phone which may indicate a line issue etc.
Pnokio
Whizz Kid
Message 7 of 10
Status
Connected
Current speeds
Download
38.0 Mbps
Upload
6.2 Mbps
George
Pnokio
Whizz Kid
Message 8 of 10
Test done using Wi Fi
I know nothing re Router Sync Speed
George
AllyM
Message 9 of 10
It might help if you supply a bit more information.
Are the slow speed tests done wired or over WiFi?
Is the router sync speed also low or just throughput?
