No wifi
TheDodo
Message 10 of 10
Hi there - I’ve just got home and I’ve got no wifi. Has anyone else lost connection in SE London - Sydenham/Forest Hill area? Just trying to asses if it’s just me or a wider  problem. Thank you.
9 REPLIES 9
Message 1 of 10
Hi TheDodo
How are you getting on following the engineer visit?
Message 2 of 10
Hi TheDodo
Please let us know how you get on following the engineer visit.
Message 3 of 10
Oh, that’s good to know for the future @martswain Thank you.
I found it strange because O2 SMS for example is always branded O2UK.
martswain
Message 4 of 10
Pretty sure that's a genuine TT or Openreach number.
Message 5 of 10
Hello Michelle
I’ve just booked an engineer, so hopefully all will be sorted soon.
However just to check - I’ve received an SMS pretending to be from TalkTalk from a dodgy looking non-branded phone number (+447378905544). They were asking for account info.
I assume it’s phishing? Just wanted to flag.
Message 6 of 10
I'm sorry to hear this and thanks for the update.
martswain
Message 7 of 10
@TheDodo normal response times for domestic faults is up to 72 hours, good luck !
TheDodo
Message 8 of 10
Thank you for your message @Skynet_TX
The light is red and I’ve done a connectivity check. Sadly it seems to be a problem between the exchange and my property. Talk Talk say they’ll dispatch an engineer soon.
Hopefully soon means hours rather than days.
Skynet_TX
Message 9 of 10
Hi @TheDodo,
What are the light(s) showing on the router ?
It would be worth going to the Service Centre to ‘run a connection test’ on your line, this will indicate if there is currently a fault affecting your service. You can also access this from the ‘My Account’ site.
The TalkTalk Support Team on this community will be able to help, they will hopefully be able to respond to this post tomorrow.
