Dropping WIFI
tom2453
Chat Champion
Message 4 of 4
Hi, its been a while since I put anything on here but I can't resolve the problem , so here goes.
I have the Sagemcom 5364 router with the latest 174 software.
For some time now I have been having problems with dropping wifi. When this happens the router shows that it is connected to the internet and I can access it via my PC.
I have turned the router off and reconnected it which resolves the problem but it may only last for a few hours or a few days. I have reset the router a number of times and then have to re-enter all the details such as reserved ip's etc. This takes a while and again I don't have any problems until it gives up again. The wifi is still broadcasting but won't allow any connections.
I have come to the conclusion that I have a faulty router but if anyone has a solution I would be very obliged.
Cheers.
3 REPLIES 3
Message 1 of 4
You're Welcome 🙂
tom2453
Chat Champion
Message 2 of 4
Thanks karl, I hope so.
Message 3 of 4
Hi Tom,
I think you may be right. I'll get a replacement router out to you and see if this helps.
