Internet not connecting after moving house
Est1882
Message 21 of 21
We recently moved house and arranged to take our broadband with us. Yesterday (5/12) was connection day and I got an email around 2pm to say that it had all been set up and ready to go...
Unfortunately, after plugging the router in it simply fails to connect to the internet. I just get a continuously flashing orange light (a "slow" blink - roughly one second on, one second off - rather than the "fast" blink when the router is first turned on).
I did a connection test from my account which initially stated that a fault had been identified (Fault Ref REP-12213126), but I then got a text message a few minutes later to say that "we've tested your broadband line and it looks like it's working as it should be".
I later went through the live chat service and none of the tests they ran identified any issues.
Does anybody have any ideas?
Only thing I can think of is that the phone socket I'm connecting to may not be the "master socket" as mentioned in the install guides (I'm not sure how to identify), but I've tried in two different sockets with the same result.
20 REPLIES 20
Message 1 of 21
Est1882
Message 2 of 21
Thanks @Gliwmaeden2
Successfully cancelled the appointment.
I guess one of the things about moving house is not knowing where the sockets are...
Gliwmaeden2
Message 3 of 21
You must cancel the engineer yourself, @Est1882, as staff won't be back before Monday.
Details if it's a Talktalk engineer:
https://community.talktalk.co.uk/t5/Articles/Your-TalkTalk-engineer-appointment/ta-p/2205431
Will edit in the BT scenario shortly.
Here it is:
https://community.talktalk.co.uk/openreachengineer
You need to get this done by noon on Saturday.
Est1882
Message 4 of 21
Hi Karl,
Is it possible to cancel the engineer's visit?
So sorry to mess you around, but we have discovered another phone socket hidden behind some furniture and we have now been able to connect successfully to the broadband.
Est1882
Message 5 of 21
Thank you
Message 6 of 21
Engineer booked for Monday 12th AM (8-1).
Message 7 of 21
i've sent you a PM to confirm some details.
Est1882
Message 8 of 21
Hi Karl,
Yes please. I think we have exhausted any other options.
Message 9 of 21
OK, as long as you are happy that the alternative router you tested with was is good working order, then we can move towards an engineer.  Would you like to arrange this now ?
Est1882
Message 10 of 21
Good morning,
I was able to try with a different router last night and still get the same result (I.e. The router does not connect to the internet).
I also tried with a BT Openreach modem between the socket and the router and this gave a slightly different result - rather than the slow orange blinking continuously after booting up, this time the router alternately flashes orange and white for a few minutes, before fixing on a solid orange light with no flashing at all. I'm still not able to connect though.
Unfortunately we've not been able to access a landline phone to do the other checks.
Message 11 of 21
Ok thanks, if we can just check if its a router issue that will help.
also, if you do have a friend or neighbour that could lend you a handset for 2 minutes to confirm a dial tone, that would confirm the line is live.
Est1882
Message 12 of 21
Yes, I do have an old router.
I will give it a go tonight and update this post with the results.
Message 13 of 21
Ok, do you have access to another router before we send this for an engineer, we can issue a new router if one is required.
Est1882
Message 14 of 21
Sorry Karl, no I don't.
Message 15 of 21
Do you have access to a handset to check if there is a dial tone ?
Est1882
Message 16 of 21
Hi Michelle,
Thanks for responding. The router was not plugged in earlier, but I went home at lunch time and tried it again in the test socket and still get the same response ("fast" orange blinking whilst the router boots up for ~40 seconds and then continuous "slow" orange blinking).
I've left it plugged in and switched on for the afternoon.
Message 17 of 21
I'm sorry to hear this. I've run a test on the line now which is clear. Is the router currently connected and switched on at the moment? Have you also tried connecting the router directly at the test socket?
Skynet_TX
Message 18 of 21
Ok, the support team here should be able to help tomorrow with running some tests. But if they are not able to detect a fault it would be really useful if you could get hold of a landline phone, even if just to borrow one for a few minutes, just to see if the line is active and clear, and that calling 17070 does read back the correct phone number.
Est1882
Message 19 of 21
Thanks @Skynet_TX
I've updated the Community Profile and attached pictures of the two phone sockets - both appear to be NTE 5 types, but I assume the "master" socket is the one that doesn't say extension on it (although I have the same result with the router in either anyway).
I don't have a landline phone so unfortunately can't complete the other tests you suggest.
Skynet_TX
Message 20 of 21
Hi @Est1882,
The Master Socket is the first phone socket that the phone line connects to when it comes into the house. Take a look at the pictures of sockets here and let us know what different types of socket you have in the house.
If you have a landline phone can you check to see if that is working normally (i.e. you have a clear dial tone and no noise on the line).
Can you also dial 17070, this will read back the phone number of the line, can you ensure this is the number you expect (i.e. the number displayed in 'My Account').
For one of the TalkTalk Support Team on this community to be able to look into this you will need to update your community profile to include :
  • Your name
  • Landline telephone number that your TalkTalk service is provided on (this is shown in ‘My Account’)
  • An alternative contact number
This will allow them to identify you, and they will then be able to help.
Don't post any personal details in this thread, just add them to your community profile (only you and the TalkTalk Support Team on this community can see your profile details).
