on 17-09-2023 10:13 AM
For the past few years I gave enjoy a failure free internet connection. Perhaps, every-now-and-again it would drop out. No problem, these things happen.
However, over the last few months the router has been dropping out almost once a week. This requires an off/on reset and all is well again. There is no facility on this router to reboot it remotely.
The main problem is that I have a Hive Heating System where the boiler can be controlled over my network. If I am away from home loss of control gives me a problem especially in bad weather. This happened to me last winter during a spell of temperatures in December as low as -12˚ . A timely arrival back home saved the day.
Not a thing has changed on my network. The same connections for a few years with no signs of trouble. I can test my system until the cows come home once it is back up and running with no indication of a problem.
My feeling is it could be an intermittent router problem or it’s down to something at TalkTalk.
on 25-09-2023 06:41 AM
Hi gcon60
That's great news, thanks for letting us know 🙂
I have sent you a Private Message with a link to a short survey for the Community.
Thanks again.
on 22-09-2023 04:14 PM
Thanks Debbie,
All good so far and my original router is now with Royal Mail winging its way back to you.
on 22-09-2023 07:55 AM
Hi gcon60
Just checking in to see if everything is still working ok?
on 20-09-2023 12:58 PM
No Problem 🙂
on 20-09-2023 12:56 PM
Successfully installed and looks good. Not long ago I reached 43Mbs and I was delighted. With this new router I got 48.5 Mbs. WOW! Over the moon.
I will continue to monitor in the hope the fault does not return. Thanks once again.
gcon60
on 20-09-2023 11:35 AM
Excellent, any problems etc, just post back here.
on 20-09-2023 11:29 AM
Router has arrived, thank you. I will set it up and install it today. gcon60
on 20-09-2023 09:53 AM
Hi gcon60
on 18-09-2023 12:27 PM
Hi gcon60
Thanks for your reply 🙂
on 18-09-2023 12:25 PM
Keith,
Thanks for you help with this. A new router is now en route so hopefully all will be good.
gcon60
on 18-09-2023 12:22 PM
Certainly Debbie and thank you for your speedy help with this. In time I will let you know the outcome.
tak tent,
gcon60
on 18-09-2023 09:48 AM
Definitely sounds like the router to me, with the light being solid red.
on 18-09-2023 08:42 AM
Hi gcon60
You can keep the new router and return old router, will this be ok?
18-09-2023 08:41 AM - edited 18-09-2023 08:42 AM
Debbie,
As the router is a possible cause of the failure it would be useful to try another one. A month would probably be a reasonable period for testing. Do you agree?
Ta
gcon60
on 18-09-2023 08:39 AM
Hi gcon60
Apologies for this. Would you like me to send a replacement router for testing?
on 18-09-2023 08:37 AM
1. Router type DG8041W
2. Solid red
3. Yes, also affected
on 18-09-2023 06:35 AM
Hi gcon60
on 17-09-2023 02:46 PM
2. What is the exact status of the lights on the front of the router when this happens?
3. If you have any wired connections, are they affected in the same way as wireless ones?
