VPN issues, please help!!!
Miri95
Message 7 of 7
Hi there,
I’ve been having issues with my VPN for quite some time now.
I never had any problems logging on, then a couple of months ago it wouldn’t let me. I need my VPN for essential work as part of my job and use it regularly and daily.
I have spoke to my works IT department who did all updates and checks and concluded it was an issue with my internet provider. This was confirmed when I used my housemates internet (different provider) and could log on. I do not plan to live in a houseshare for much longer so need this issue fixed asap as when I move out I won’t have any access to my VPN. I work from home so it’s essential I have this support.
I have spoke to TalkTalk customer services numerous times about this who said VPN issues aren’t they’re problem but I refuse to believe this as it is clear that TalkTalk is blocking the VPN somehow. My IT department has exhausted every option they can. So this is clearly an issue with TalkTalk.
Can someone please help!!! It’s driving me a bit crazy and I’ve had no support or solution for this. I requested a new router but they refused. I really need to get on the VPN but it just comes up with an error message each time. Please help!!
Many thanks.
6 REPLIES 6
Message 1 of 7
Hi Miri95
I'm so glad to hear this 🙂
I have sent you a Private Message with a link to short survey for the Community.
Miri95
Message 2 of 7
Hi Debbie,
Just tested it now and it works again, I can successfully connect to it! Thanks so much for your help, big sigh of a relief
Message 3 of 7
Hi Miri95
I've made a change to your router firmware, please can you retest?
Skynet_TX
Message 4 of 7
Hi @Miri95,
If you have the Sagemcom Wi-Fi Hub then this will probably have been caused by the firmware upgrading to a new version.
What VPN software do you use, or is it the built in Windows 10/11 VPN ?
The support team here will be able to help, if you do have the Sagemcom they will probably be able to fix it by changing the firmware, they probably won't be around until Monday now, but they will reply as soon as they can.
Miri95
Message 5 of 7
Hi Karl,
I have provided my home phone number, please be aware it is not in use.
Message 6 of 7
So that I can locate your account on our system and pick this issue up for you, please can you add your Account number or Home phone number to your 'Community Profile'.
If you are a Full Fibre customer, please add your FTTP reference or FTTP order Number to your profile.
If you have difficulty providing the above information, please add the Account Holders name, House number and postcode to the Private Notes section that is located at the bottom of your 'Community Profile'
