Ch 5 audio delay
SteveB86
Message 4 of 4
A little bit before Christmas we got our new Talk Talk TV box all is fine other than the audio on channel 5 is delayed slightly, which is very off putting. Any suggestions? Thanks
Steve
Steve Baldwin
3 REPLIES 3
Message 1 of 4
I noticed this within the My5 app, I turned off the surround setting, restarted the box and tested again, and this seems to work in that app.
SteveB86
Message 2 of 4
Thanks for coming back, we have only noticed it on the one channel, I will try your suggestion a bit later.
Steve Baldwin
Message 3 of 4
Are all other players ok ?
If you go to settings then Device Preferences, then Sounds, and turn off Surround sound, does this help at all ?
