New TalkTalk TV Hub Mod UZW4054TTG
jammyjames44
Message 6 of 6
How to delete items from watch list on new tv hub (the delete on the remote doesn't do it).
5 REPLIES 5
Message 1 of 6
The OP is talking about deleting items from the watchlist, which is in MyTV, not recordings @Paghammalc
Paghammalc
Message 2 of 6
You cannot record on the new Hub
Message 3 of 6
glad you worked this out.
jammyjames44
Message 4 of 6
I have realised that you have to 'open' the MYTV App, then select the desired film/program, highlight it and then use the red button on the remote to delete it (not the delete button); then OK and it's gone.
Sorted.
Message 5 of 6
Try the info button. There is usually a delete option shown on YouView boxes, on which the hub is based.
