Remote - only some buttons work.
Prastio
Message 2 of 2
My remote previously worked OK.  Recently it stopped responding to the on/off TV and box commands.  I can still use Guide, change channels volume etc.
Tried a reset 1 + 6 buttons, new batteries, restarted box but problem still exists.
Any suggestions?
1 REPLY 1
Message 1 of 2
I can see a Remote Control has been ordered for you on Saturday and is on the way to you.
