Talktalk tv hub
Holidays
Message 3 of 3
My tv keeps buffering during programmes and rewinding
Message 1 of 3
Did you follow the advice from fr8ys ?
Message 2 of 3
What steps have you taken to rectify this?
Reboot router? Reboot / reset box?
I assume rewinding is only whilst using catch up apps?
Have you run a speed test?
How is the box connected to the router? WiFi, power lines or direct ethernet.
If you can provide this information we can then offer more advice.
Thank you.
