Uview box
MILLSIE
Message 3 of 3
Uview box keeps freezing up.  Everything changes in slow motion. Until it stops altogether.the only way to get it moving again is to turn the power off at the back then back on. Press the on button at the front then wait for it to restart. It works for a bit before starting to freeze again. Any suggestions please.
Message 1 of 3
Hi MILLSIE
Did the advice from fr8ys help ?
Message 2 of 3
have you tried a YouView Maintenance Reset (https://community.talktalk.co.uk/t5/Articles/How-to-find-maintenance-mode/ta-p/1429347)?
If all else fails then try a full factory reset lose recordings. This will format the hard drive and hopefully restore the box to working order.
Hope it works but if not then please let us know and we can advise on options going forward.
