problems with subtitles
hansam
Message 10 of 10
Just received my new TV hub and remote. When I select subtitles for films and some programes, the subtitles remain on screen for every other show. when I go to settings, the subtitle option is 'off' but they still show on screen. Solution??
9 REPLIES 9
Message 1 of 10
No downloadable manual available however there is help content that you can search via the option at the top pf the community page.
hansam
Message 2 of 10
Thank you, tested numerous times, must be a fault, on hub. Settings show 'subtitles' display as 'off', i then need to press again to show 'on'  again for 'off' for them to disappear off screen.
Tried selecting subtitles 'on' while watching a programme, then turning 'off' before exiting programme to see if that turned off the subtitles altogether, didn't work, still needed to go to 'settings'
I don't want to go to factory reset, been frustrating getting used to the new TV hub already.
Thank you for your help, a manual would have been helpful, is there a download to my computer available?
Message 3 of 10
You would have to sign back in to all apps etc if the unit is factory reset.
Message 4 of 10
Just tested again, to make sure it is still happening! If i take it back to factory settings, will I lose anything that I have already set up?
Message 5 of 10
I've been testing on my hub here, and cannot recreate this.  The subtitles are working correctly, and when I turn these off, they are then not showing on any other channel.
Try a factory reset - Settings - Device Preferences - Factory Reset, and see if this clears the issue.
hansam
Message 6 of 10
No, until i turn on subtitles for a particular programme, they are not on screen. If I turn on for a particular programme, they appear on all after that. I go to settings, options for subtitles shows as 'off', but I still need to click to turn off repeatedly.
Message 7 of 10
Are these within a specific app, or channel ?
hansam
Message 8 of 10
Yes
Message 9 of 10
Have you tried powering off the box for a few minutes ?
