Wi-Fi Calling allows you to make and receive calls even if you can’t connect to your mobile network. When you're connected to Wi-Fi, you can just dial the number you want like normal.
During these unprecedented times it's important we all work together to reduce the strain on the UK's mobile networks. If you're at home or have a Wi-Fi connection, you should look to use Wi-Fi calling wherever possible.
Wi-Fi Calling doesn’t require an app. Once activated, dial as normal
Make calls from your home or if you're out. Wherever there’s Wi-Fi, you can call
Once you've connected to a Wi-Fi network, you'll automatically connect in the future
Wi-Fi calls will come out of your call allowance or be billed as normal
Make sure Wi-Fi Calling is set to On. To switch off Wi-Fi Calling, set the toggle to Off.
The menu steps may vary on older models.
Make sure Wi-Fi calling is set to On. To switch off Wi-Fi Calling, set the toggle to Off.
The menu steps may vary between different Huawei models.
The menu steps may vary with different LG models.
The menu steps may vary with different HTC models.
