Each of our TalkTalk TV boxes work differently when it comes to the record, pause and rewind feature. You'll find all the information you need about each box and the differences below.
Features | TalkTalk TV Hub | TalkTalk TV 4K Box | TalkTalk TV Box | TalkTalk TV Plus Box DN372T |
TalkTalk TV Plus Box DN370T |
Pause & Rewind (Subject to HD/SD quality) |
Approx. 30-45 mins |
Approx. 60-120 mins |
Approx. 30 mins |
Approx. 120 mins |
Approx. 120 mins |
Record | Access content through On Demand | Access content through On Demand |
The TalkTalk TV Hub does not have a recording function. However, there’s no need to record! Not anymore…Never miss a show again when you have access to so much more. With so many On Demand players already pre-installed in your featured apps and so many more available in the Google Play Store, you'll be spoilt for choice with on demand content.
You don’t have to remember to record, it's all available On Demand. Simply catch up at a time that suits you across one of our on-demand players. Use Google Assistant to search for the show you want, and let the TV Hub do the rest. Or, with the new ‘Watchlist’ feature, you can now find your favourite and last watched shows across all catch up players in one place.
If you're watching live TV, you can pause or rewind at any point. Simply use the pause, rewind and play buttons on your TV Hub remote. The amount of time you can rewind back to is dependent on the quality of the programme you're watching.
For more information or if you're experiencing problems with the pause or rewind features, take a look at our helpful information below.
You can pause live TV and then restart viewing or fast forward / rewind back to the point you paused the programme. However, you cannot immediately rewind live TV to an earlier time.
You can pause live TV (for a minimum of 15 seconds) and then restart viewing or fast forward / rewind back to the point you paused the programme. However, you cannot immediately rewind live TV to an earlier time.
For more information or If you're experiencing problems playing your recordings with the TalkTalk TV Plus Box, take a look at our helpful information below.
Your TV Plus box can record two Freeview channels at the same time or you can watch one channel while recording another. You'll be able to record up to 185 hours of standard definition TV programmes.
You can pause or rewind at any point while watching live TV. Simply use the pause, rewind and play buttons on your remote. The amount of time you can rewind back to is dependent on the TV box you have. This can be seen in the table above.
Record a programme or series in three easy steps:
All content in the Guide can be recorded, including:
Content in the backwards guide can't be recorded. This content is usually available for a week or more giving you plenty of time to catch up on anything you've missed.
Your programme will no longer be recorded. You can also cancel your recordings via the Guide. To do this simply press the record (red R) button on the programme you'd like to cancel.
Your TalkTalk TV Plus box can record up to 185 hours of Standard Definition or 60 hours of High Definition TV programmes and films from the Guide. If you have lots of recordings, it's easy to check the remaining space. If you're near the limit, the Automatic Delete feature will help to free up space.
At the bottom of the screen, you'll see a progress bar which displays the percentage of free space available.
To help free up space on your TalkTalk TV Plus box, and ensure scheduled recordings are successful, you can set your Box to automatically delete content. This will start with the oldest recording when it's about to reach it's limit. To make sure a recording doesn't get deleted, lock it in MyTV.
If you want to manually manage your recordings then follow the steps below to turn this feature off:
To protect individual recordings from being deleted, you can lock them.
Once you have recorded a programme or film it will be stored on your box to watch any time.
If you're experiencing problems playing your recordings with the TalkTalk TV Plus box, take a look at our helpful information below.
If you're seeing a YVM210 error message, this means you have our TalkTalk TV box which can't record. Only the TalkTalk TV Plus Box can record.
If you're unable to play back a recording it's likely that it has failed. We're unable to recover failed recordings. We recommend checking the Players & Apps area or the backwards guide to see if your chosen programme is available to watch there. You can also check the guide to see if it's due to be repeated, and record it again.
If you try to record too many programmes at the same time in the Guide, it will create a clash. However, you can still watch:
You will be able to record two programmes whilst watching On Demand content or a previous recording.
First thing to try is rebooting your TV box. As simple as it sounds, this can often resolve your issues playing your recordings. To do this, press the power button on the back of your TV box.
Power button
Maintenance or recovery mode is useful to reset your TalkTalk TV box, but you should only use this option after all other diagnostics have been completed.
To do this, you will need to follow our instructions for TalkTalk TV plus box Maintenance mode.
factory reset
Maintenance mode
If maintenance mode rest doesn’t work, the final suggestion before contacting us is to do a full factory reset. You'll find this by pressing the Youview / Menu button and press the up arrow to select Settings.
It's important to the remember this may resolve your issue, however will delete all your existing recordings.
We know how frustrating it can be if your recording isn't successful. Often this is caused by a rescheduling of your programme, lack of recording space or a connection problem.
If your recording says failed even before the programme is due to be broadcast this is often because the broadcaster has changed the programme information. We use this to track the start and end of the programme in the programme guide. In a lot of cases, the title, date and time do not change and the broadcaster provides sufficient additional information to allow us to find the replacement and record it successfully. If a programme is cancelled from the schedule by the broadcaster then it will fail to record.
Incomplete recordings are often caused by an incorrect broadcaster's signal or a schedule change which was not updated in time (for example, extra time and penalties during a sporting event). If you do end up missing the end of a show, it might be worth looking to see if a programme has been on before and watching it again by going backwards through the programme guide. If you visit the Players & Apps area you'll also be able to catch up on programmes in the BBC iPlayer, All4 and Demand 5.
If you plan to record a programme that is likely to overrun, such as a live event or match, it's worth recording the programme after it as well so that you don’t miss any of the coverage.
If you're having problems with the picture quality of your recording, this is often due to a poor connection. The cause depends on what type of content you were recording:
If you're experiencing a loss of sound on just one channel it may be a problem with the broadcaster. If the loss of sound is on all channels the following steps will help resolve the issue.
To make sure there are no disappointments when it comes to playing back your recordings, follow our 3 tips below:
Leave your box on or in standby mode. If you switch it off at the mains or power it down, it won't record
Check your TV aerial cable is firmly connected to your TV box and also plugged in your wall socket
If your programme is likely to overrun, record the programme after it too so you don't miss any coverage
