Set up your Wi-Fi Hub
No ratings
Your new Wi-Fi Hub is a breeze to get connected. Simply plug it in, switch it on and away you go. Before you get started, make sure you unplug your old router and any other broadband equipment.
Getting to know your Wi-Fi Hub
Take a moment to familiarise yourself with your Wi-Fi Hub, this will help you to set it up:
Back of the Wi-Fi Hub with numbered markers pointing to each component
1. Broadband port
2. WPS button
3. Wi-Fi settings card
4. Ethernet ports
5. WAN port
6. Reset button
7. Power button
8. Power port
Light guide
The light on the front of your Wi-Fi Hub will change colour depending on the status of your connection.
Front of Wi-Fi Hub
  1. Blinking amber – Your Wi-Fi Hub is starting up.
  2. Blinking amber and white – Your Wi-Fi Hub is connecting to the Internet.
  3. Solid white – You’re connected to the Internet.
  4. Solid amber – Your Wi-Fi Hub is verifying your connection. If you’ve got Fibre you should wait a few minutes. If you haven’t got Fibre, or the light stays solid amber for more than 15 minutes, please contact us.
Watch our video
View this video with British Sign Language.
Getting set up
First you'll need to find your master socket. This is the main phone socket in your home - it’s usually a little larger than a normal phone socket and often has a horizontal line in the middle. There are two types of master socket:
Standard master socket
Standard master sockets have one port on the front, which means you need a microfilter to connect your phone or router. You'll also need to use microfilters in every other socket you're using in your home.
router and phone plugged into standard master socket
Pre-filtered master socket
Pre-filtered master sockets have two ports on the front, which means your line is already split between your phone and broadband connection. You can plug your phone and router straight into a pre-filtered master socket without using any microfilters.
router and phone plugged into pre-filtered master socket
Connect your router
The way you set your router up depends on which master socket you have. Choose yours from the options below.
  1. Plug the microfilter with the broadband cable attached into the master socket.
  2. Plug the other end of the broadband cable into the broadband port on your Wi-Fi Hub.
  3. Insert the power cable into the Wi-Fi Hub’s power port and plug it into the wall. Turn on the switch.
  4. Push the Wi-Fi Hub’s power button.
  5. The light on the front of the Wi-Fi Hub will come on.
Wi-Fi Hub connected to master socket with a microfilter
  1. Plug the broadband cable straight into the top or left-hand port on the master socket.
  3. Insert the power cable into the Wi-Fi Hub’s power port and plug into the wall. Turn on the switch.
Wi-Fi Hub connected directly to the master socket without a microfilter
Using a wired connection
To use a wired connection, simply plug the Ethernet cable into your device. Then plug the other end into any of the yellow Ethernet ports on the back of your Wi-Fi Hub.
Wi-Fi Hub connected to a laptop with an Ethernet cable
Connecting using WPS
Wi-Fi Protected Setup (WPS) lets you easily connect network equipment like wireless printers to your router. Instead of manually typing in your Wi-Fi password, you simply press the WPS button on your Wi-Fi Hub to connect your device. Here’s how to do it:
  1. Follow the instructions that came with your device about connecting using WPS.
  2. Press the WPS button on the back of your Wi-Fi Hub until the LED on the front of your Wi-Fi Hub starts flashing amber.
  3. When your device has connected to your Wi-Fi Hub, the LED will turn solid white.
  4. If the connection fails, the LED will flash amber again before returning to solid white.
  5. Wait until the LED turns solid white and then try to connect again.
Got UFO or Faster 150 Fibre?
Your setup will be a little different from the above. Here's how to set up your Wi-Fi Hub if you have UFO and how to get set up if you've got Faster 150 Fibre.
Tayler
Hi, I’m Tayler did you find my article useful?
Need to speak to our team?
Our experts are here to help, select one of the following contact options:
To help us deal with your query quickly, please confirm the following information when you write to us. We will aim to respond in writing to your query in 10 days.
- Your full name
- Your TalkTalk Phone or mobile number
- Your Signature
TalkTalk Correspondence Dept
PO Box 675
Salford
M5 0NL
All letters will be sent to the primary billing address unless stated otherwise. Please also include the best way to contact you about your query, such as your contact phone number or contact address.
Call us for free on: 0345 172 0088
Make sure you have your account details to hand when you call.
Calls are free from your TalkTalk phone, our customer services team are available 8am-8pm, Technical Support 24/7 every day. If you’re deaf, hard of hearing or speech-impaired, the Text Relay Service can be used to help you contact us, simply dial 18001 followed by 0345 1720088
