Ads in japanese
adamp1392
Message 2 of 2
Hi all, moved into this new house with some people, wifi was already set up. I am getting a problem where ads on my laptop, smart tv are in japanese (or another asian language im not sure)
Some of the search results are in the same language.
Does TalkTalk think I am in japan? how to fix?
I also use honeygain ( uses data to make money ) and that is now not work aswell.
Thank you
1 REPLY 1
Divsec
Message 1 of 2
Hi @adamp1392 you don't mention which router you inherited but it is likely the dns settings were set to a Japanese  server.  Easy enough to reverse. https://community.talktalk.co.uk/t5/Articles/Using-3rd-Party-DNS/ta-p/2205279 will help
From the 29th of March our TalkTalk Community will move to peer-to-peer support and the TalkTalk team will no longer be here to support with queries. Don't worry we still have plenty of ways to reach out if you need to speak to TalkTalk directly. For more details check out the link here: How to contact TalkTalk Broadband - Help & Support. 03451720088
