BB very slow, frequent loss of connection
simop
Message 20 of 20
For several weeks our BB connection has been very slow. The talk talk speed test is showing ~10.3M/sec whereas it used to be around 40M/sec.  Upload speed is only 0.3M/sec.
Sometimes the connection is fine, and other times it is near unusable. As well as the slow speeds there are also frequent dropouts where we entirely lose connection for a few minutes.
The above happens both with WiFi and wired connections to the router.
Any ideas what could be the problem and how to resolve it? I tried the troubleshooting section on the talk talk support page but it eventually presents me with a 'live chat' link that doesn't work.
Thanks!
19 REPLIES 19
Message 1 of 20
Hi simop
How are you getting on, have you received the replacement router?
Message 2 of 20
Hi simop
simop
Message 3 of 20
Yes, please do send a router. Thanks.
Message 4 of 20
Hi simop
Will it be ok If I send you a router so we can rule this out?
simop
Message 5 of 20
No - we're still using the original router from when we signed up to TalkTalk.
Message 6 of 20
Hi simop
Apologies for this.
Have we recently sent you a router for testing?
simop
Message 7 of 20
Hi Debbie,
For a day or two I got pretty decent speeds. Today, however, the speeds are really slow again: I can several speed tests and they show between 5M/sec and 15M/sec.
The connection also keeps dropping again, with web pages timing out quite frequently.
Message 8 of 20
Hi simop
What speed are you now receiving when running a speed test?
Message 9 of 20
Hi simop
Please can you try one more 30 minute power down of the router and then confirm what speed you receive on the speed test once the router is switched back on?
simop
Message 10 of 20
Yes, was down for a couple of hours. Can try again if you think that'd help.
Message 11 of 20
Hi simop
Did you power down the router for a full 30 minutes?
simop
Message 12 of 20
The connection continues to be stable without the dropouts we saw before...but the speed is still very low. Speedtest is showing 9.8M/sec and the "Speed to your router" section of the talk talk page is showing only 22M/sec. So something is still not right with the network, would be grateful if you could have another look. Thanks!
Message 13 of 20
Message 14 of 20
Hi simop
Your line is showing in sync at 40mb. Please can you power down the router for a full 30 minutes and then run another speed test?
simop
Message 15 of 20
Hi Debbie,
I was just looking at this. Our connection seems stable but is still slow. Running the talk talk speed test gives ~17M/sec, so roughly half of what we should be getting.
Message 16 of 20
Hi simop
Openreach have now closed this fault - In Joint AreaCable (Underground)
Is everything working ok now?
Message 17 of 20
Hi simop
I have passed this fault straight over to Openreach to be investigated by a line engineer.
I will continue to monitor for additional updates from Openreach.
simop
Message 18 of 20
Hi, thanks for the reply.
We don't use the voice service and have no landline telephone - so I don't know if that is affected or not.
Message 19 of 20
I'm sorry to hear this and I will take a look now. I've run a test on the line which has detected a potential voice fault. Are you experiencing any issues with the voice service such as noise on the line or no dial tone?
