Broad band signal
Paulthornhill
Message 2 of 2
My broad band signal doesn’t seem to cover the whole of my house; is there a booster available?
1 REPLY 1
Message 1 of 2
That all depends on the package that you are on & which make/model of router you have. However, first, an assessment needs to be done by myself into how much WiFi interference is present.
