F@st 266 causing instability to all wifi. More stable when unplugged
BillyH1234
Message 3 of 3
Hi there,
I've had a 266 installed for 6 months. Since then I have found WiFi in whole house (including direct from router) to have become more unstable. Having unplugged the 266 the wifi is now more stable.
Can anyone recommend an alternative extender or booster to TalkTalk's own SAGEMCOME 266?
Message 1 of 3
Hi @BillyH1234
@Anonymous has asked me to help you. I would suggest you first check for WiFi interference, I have never come across a situation where the 266 made things worse. Slow speed, intermittent dropouts, breaks in the signal or no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a byproduct of the popularity of Wi-Fi.
The next stage involves sending out a guide to you to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
Message 2 of 3
Hi Billy,
I'm sorry to hear this. Have you tried resetting the wireless adapter? @KeithFrench do you have any other suggestions please?
