on 05-11-2023 10:55 AM
I have 8 wired devices connected to my DG8041W-2T5 router via powerline adaptors. Logging into the router and checking the wired connections only 3 are named the others are just dashes. I recently needed to enter the IP address of 1 device to be able to get it to connect to my phone but as it wasn’t named I ended up disconnecting the devices one at a time until I found the correct IP address for that device.
Is there a way of manually entering a name for each connected device?
Thank you
on 27-12-2023 02:55 PM
Hi @michellegee
To answer your question log into the router, click on:-
Dashboard > Manage My Devices > Manage advanced settings
Anything else please create a new thread of your own, you cannot use someone else's thread.
To get help, you must start your own thread. To create your own thread, go to the main page for the board in question & click the "Start a topic" button.
TalkTalk insists on one thread per problem per customer. Please note, TalkTalk makes the rules, not me.
on 27-12-2023 02:41 PM
Can you tell me how I get into Advanced Mode please, I can't find it on my menu.
on 06-11-2023 02:52 PM
You're very welcome.
on 06-11-2023 02:48 PM
Thanks for this info. All done .
on 05-11-2023 03:04 PM
Yes, there is.
Go into Advanced mode & from there go to System Information > User Device Information.
Go into Details & set the device name in the User Alias box.
