Faulty hub, no internet for a week
monkeymagic101
Message 4 of 4
My hub has lost all internet connection and is just constantly flashing amber.
I've tried all the fixes I can find, turned off for 20 min and back on, reset button on the back, changed cables. Used a microfilter and the test socket.
Twice on to talktalk, first refused to believe it's the router and wanted to send an engineer out to look at the socket ( this was changed last year and is the newest one ). I work nights and can't guarantee I'll be awake when one would come.
The second has told me it's a faulty ethernet cable that's causing the problem and I'm waiting on that cable to be delivered. I don't believe an ethernet cable between my hub and my device is causing my hub not to connect to the internet as I'm not sure how it could. I've spare cables anyway and have tried changing them all but I've no WiFi either and no cable except the one that connects the hub to the socket will affect this (that's not the cable they think is faulty tho)
I can connect to the hub using my phone and have been able to get in to the settings. It literally says it's not connected to the internet but talktalk don't seem to believe me on this. I even sent a screen shot. In my opinion I just need a replacement hub.
3 REPLIES 3
Message 1 of 4
How are you getting on? Do you still need assistance with this?
Message 2 of 4
  • Name
  • Telephone number
  • Alternative contact number
Message 3 of 4
This indicates that the router has lost connection with the broadband equipment, it could be the router or the line. It needs testing first. I have asked one of TalkTalk's support to pick your thread up and investigate it for you.
They aim to respond within 48 hours (Monday - Friday) excluding Bank Holidays, but if more urgent you can always try the Service Centre on 0345 172 0088. The posts are responded to in time/date order, oldest first. Please try to avoid posting on here until TalkTalk has responded to you, otherwise, this will just put you further down the queue.
