Frequent disconnections...
mikeyb200
Message 74 of 74
I'm getting periods where my router (Sagemcom Fast 2) frequently disconnects the broadband. It'll run fine for a few weeks, then we get another episode of instability. We're in one now, hence this post.
Running the TT line test shows no problem with the line - instead it suggests there are Wifi connectivity issues in the house. There aren't!
Looking in the Router Admin, it always shows the Downstream Noise Margin as 0dB. Surely this is the problem - I've always understood the minimum stable noise margin to be about 6dB.
So is it the line or the router? The router has already been replaced by TT twice before - so we're on our third one since moving here 3 years ago.
All very frustrating!
73 REPLIES 73
mikeyb200
Message 1 of 74
Hi @ferguson , sadly no fibre here yet. Hopefully arriving at some point during 2026, so I'm just trying to soldier on with this set-up until then.
Message 2 of 74
Wise move. I'm stopping indoors with a can and the darts on the telly! 🙂
mikeyb200
Message 3 of 74
Sure.
Thanks. I'm off down the pub now!
Message 4 of 74
Do you not have Full Fibre available in your area yet?
Message 5 of 74
OK, but maybe the router reset has helped, let's see. Just post again if you have any further issues.
mikeyb200
Message 6 of 74
Yes. And it might behave for an hour, or a day, or a week.
But a TT line test never shows any problem.
Message 7 of 74
So is it connected now?
mikeyb200
Message 8 of 74
Been there, done that.  It's driving me nuts!
Message 9 of 74
Just keep an eye on it. If it disconnects again, then try connecting at the test socket with a plugin microfilter.
mikeyb200
Message 10 of 74
.... proceed?
mikeyb200
Message 11 of 74
@ferguson Yes, working currently. But the underlying issue is, I suspect, unresolved.
Do you have any suggestions how I
Message 12 of 74
Yep, if you @ mention me as you have done here I will pick it up, within reason! So all working OK just now?
mikeyb200
Message 13 of 74
OK I'm back to 'normal'. Are you there, @ferguson ?
mikeyb200
Message 14 of 74
Thank you. I could not make the person I was dealing with understand that!
I'm resetting stuff right now...
Message 15 of 74
It's not for me to mind, I am just a punter the same as you! I guess the support team have knocked off for the weekend now. Changing the WiFi settings to those of your choice will have no effect on the underlying external connection.
mikeyb200
Message 16 of 74
Ah, so you don't mind if I put the Router back as it was?
Message 17 of 74
Is the router still connected? You will need to reset SSID and password from scratch sadly.
mikeyb200
Message 18 of 74
So what happens now?
Message 19 of 74
@siphosethu-TT
Forgive me, but it would have been nice to at least ask if a remote reset was agreeable, rather than just going ahead with it.
mikeyb200
Message 20 of 74
Everything in the house has lost Wifi connection except my Mac, which 'knows' the original  SSID and PW  of the router.
