Full fibre 150 eero only 2 connections
Izzytiger3011
Message 5 of 5
I had the new full fibre 150 eero installed but it only has 2 connections I need to connect my cctv so I can use it on my iPhone with the old system had plenty of sockets on the modem how can I increase the number of sockets
thanks
4 REPLIES 4
Message 1 of 5
Personally I'd go for this one:-
https://www.amazon.co.uk/TP-Link-LS1005G-Wallmount-Ethernet-Splitter/dp/B07VWB347G/ref=asc_df_B07VWB...
Izzytiger3011
Message 2 of 5
Izzytiger3011
Message 3 of 5
5 Port 1000M Gigabit Network Switch RJ45 LAN Desktop Ethernet Shunt (EU)
is this one ok to use
Message 4 of 5
You will need to buy a small gigabit switch to expand the number of gigabit Ethernet ports (1000M). They are often sold quite cheaply on a famous online website.
