How to use a vpn
dekor8tor
Message 2 of 2
Hi can anyone tell me how to use a vpn on eero pro 6 thanks
1 REPLY 1
Message 1 of 2
You cannot run a VPN client on any TalkTalk router, but you can install it on one or more of your devices and run the VPN-encrypted tunnel through any TalkTalk router. This gives you the extra protection of further encryption over your Wi-Fi link to your router. That said, we are currently seeing some issues with the Cisco AnyConnect VPN client, so if you have a choice, use another one.
