Huawei-DG8041W
Churchy
Message 14 of 14
I have a Huawei-DG8041W and this morning  it has stopped showing the blue connection light. I have tried switching it on/off and reset but only shows the orange set up light before connection then goes blank. Internet works fine but cannot tell at a glance if its working..
Can anyone confirm its a fault with the light on the router, if so can I get a replacement from Talk Talk, only just renewed contract and had this router for 30 months.
13 REPLIES 13
Message 1 of 14
Hi John
Thanks for taking the time to complete our survey, it's appreciated.
Debbie 🙂
Message 2 of 14
Message 3 of 14
Hi John
At the top righthand corner of the Community if you click on your avatar, it should show the envelope icon.
The message will be there 🙂
Message 4 of 14
Hi Debbie. Can't seem to find the private message, how do I find the link?
John
Message 5 of 14
Hi John
That's great news, thanks for letting us know 🙂
I have sent you a Private Message with a link to a short survey for the Community.
Thanks again.
Churchy
Message 6 of 14
Hi Debbie
Test router has just arrived and have connected it and everything now works fine. Will return the faulty router in the packaging supplied. Thank you very must for your swift action and resolving the fault, Your a star.
John
Message 7 of 14
Message 8 of 14
Thank you.
Message 9 of 14
Hi  John
No problem 🙂
Message 10 of 14
Hi Debbie  if you could arrange this it would be very much appreciated, thank you. John.
Message 11 of 14
Hi Churchy
Yes, this would be a free router for testing.
Churchy
Message 12 of 14
Hi Michelle, is this a free service?
Message 13 of 14
Sorry to hear this. I've run a test on the line now which is clear. We can send a replacement router for testing purposes and a router returns bag so that the original router can be returned, would this be ok?
