I can’t access my work VPN (Zscaler) using Talk Talk broadband
Crhelp
Message 5 of 5
I can’t access my work VPN (Zscaler) using Talk Talk broadband.
I can access my work VPN using mobile data. I can access my work VPN on other wifi.
Until a few weeks ago, when I got a new PC build, I connected to work VPN without a problem. First with Checkpoint VPN and then AWS RAS VPN. My broadband has not changed. My home access is fine.
The issue is new and appears to be a combination of Zscaler and my broadband. On their own and with other components they work. But together they cannot maintain a tunnel.
@jtisc had the same issue recently which @Debbie-TalkTalk was able to resolve.
4 REPLIES 4
Message 1 of 5
Hi Crhelp
Message 2 of 5
Hi Crhelp
Thank you 🙂
Crhelp
Message 3 of 5
@Debbie-TalkTalk - no problem for the delay. Yes I am happy to try a different router. Thank you
Message 4 of 5
Hi Crhelp
Apologies for the delay.
I will need to send you a different make and model of router. Are you happy for me to arrange this?
