on 16-07-2025 10:03 AM
Approximately 2-3 months ago I started getting slow internet and sometimes it stopped. After a short time it went back to normal again. I went through the system and in the end it was diagnosed as a router problem so you replaced the router, but it is still happening. It may not happen for a few hours but then it starts again. I have gone through all the checks, disconnecting any other devices, restarting router etc but it does not stop the problem. A friend who is experienced with comms explained that I should look at the router logs but it seems that at my end I cannot look at the logs, it must be restricted to Talk Talk. He is also said there was some noise on the line, not something that I had noticed. When working correctly the speed test comes in at between 12 & 14, sometimes (like this morning) it dropped to 7 and can go down to between 1 & 2. When it stops completely the speed check service cannot connect to the server. As I said this is an intermittent problem, Can you advise what I should do next to resolve the issue?
on 19-08-2025 03:20 PM
Thank you @Gliwmaeden2 for helping out.
on 19-08-2025 03:19 PM
Does this only happen when you are making calls? or both when you make and receive calls?
on 19-08-2025 03:15 PM
Yes a couple of people have said that at times the line is noisy but it does not happen all the time, they described it as a crackling sound
on 19-08-2025 03:12 PM
@garyp41, do you have noise on the phone line at all?
on 19-08-2025 03:06 PM
No that is correct only 5 devices:
Desktop PC - connected and in use
Ipad - connected but not in use
Samsung smart phone - connected but not in use
Auto Cadlite - connected and minimal use
Motorola - connected but history from end of last week
on 19-08-2025 02:59 PM
Thank you, we have detected only five devices, please confirm if there are any other devices that I did not mention but connected at the moment?
on 19-08-2025 02:33 PM
Yes running at 12.9
19-08-2025 02:32 PM - edited 19-08-2025 02:32 PM
Is the connection still fine?
on 19-08-2025 02:20 PM
No problem, I am sat here monitoring mail so if you need anything from me then let me know
on 19-08-2025 02:18 PM
Okay thank you for allowing us to proceed with the checks. We'll need to check what your current speed is at this moment in time.
on 19-08-2025 02:11 PM
I have found the guide how to remove devices on the Internet but my initial panic is over as I have spoken to my grandson and he does have a Motorola smart phone so it is his but not being used on my wi-fi at present.
While you are carrying out any tests I will not remove it, something I will do later
on 19-08-2025 02:08 PM
I completely understand. We cannot disconnect this device from your Wi-Fi our end, but we can provide and guide you with the steps on how this can be done, is that fine?
on 19-08-2025 02:05 PM
@Gliwmaeden2 , thank you for sharing that information.
on 19-08-2025 02:03 PM
That makes sense I think that would have been our grandson who was here at the end of last week
on 19-08-2025 02:01 PM
The ACTO CADLITE is I believe the Octopus energy mini ipad which connects to the smart meters (Gas & Electric) and allows real time usage to be displayed. I sometimes use this via an app on the IPAD but it is not currently being used.
I am still confused (and concerned) about the Motorola phone. Can you disconnect it from the wi-fi?
@garyp41 , devices tend to show up for a full week after use on WiFi, so if any visitors were around within the past 8 days, that can account for unrecognised devices.
on 19-08-2025 01:56 PM
I can see the iPad, PC, a Samsung phone and Motorola phone on my end. There is also a device named "ACTO-CADLITE".
on 19-08-2025 01:53 PM
I have no idea where the Motorola phone comes into the equation, I do not have a smart phone and my wife has the Samsung which she is not using.
If any of our family visit they may have a Motorola phone and they do connect, but nobody is here now so I cannot see it should be connected which I find odd.
If you need to check into it then please do or if it is a better alternative you can disconnect it
on 19-08-2025 01:46 PM
I can also see a Motorola phone; can we check into this device as well?
on 19-08-2025 01:41 PM
As far as I am aware the devices are:
Desktop PC - inuse
IPad - most probably connected but not in use
Samsung phone - connected but not in use
There is a possibility you will see an Apple IPAD, this is used by our grandchildren but very seldom and at present it is switched off
There is also an Octopus Energy mini ipad which connects to the smart meters, this has only been connected in the last month or so, long after I started to get the problem.
If it helps your test I can switch all these devices off.
