Internet speed
Wendy012
Message 3 of 3
My speed is running Terrible.. See Below.. This needs to be sorted from your end.. Can you please sort this out for me.. Thanks, Wendy..
Speed to your device
Status: Poor
8 Mbps download
15 Mbps upload
The guaranteed download speed to your home TalkTalk router is 59 Mpbs
Message 1 of 3
How are you getting on? Do you still need assistance with this?
Message 2 of 3
If the speed to your device is poor, this may not be TalkTalk's fault, but does need investigation.
If you log into your router, what does it show the internet speed as? This is often in the main dashboard area, if you have one of the Wi-Fi hubs.
If you do not know how to do this, please can you tell me the make/model of the router that you have?
What sort of device is it that is reporting the speed as poor & how does it connect to the router - via a wired (Ethernet) or wireless connection?
