My connection keeps dropping outs
AnnieMin
Message 55 of 55
I am experiencing a very annoy issue that my internet connection suddenly became very unstable since days ago, router's light constantly went amber, lost connection but reconnect again every around 10 minutes,  I've tried to restart the router after turning power off for half-hour but the problem remains.
I've run an online connection test but no issue reported.
I also checked the router's few latest logs it says:
28.10.2023 23:10:29ErrorDNS
DNS name resolution failure (32.156.90.20.in-addr.arpa)
28.10.2023 23:10:08InfoSYS
TR-069 connectivity to (acs.talktalk.co.uk) has been closed
28.10.2023 23:10:05InfoDHCPC
The WAN DHCP client IP address 78.147.219.88
28.10.2023 23:09:31InfoDHCPC
WAN DHCP client (1) started
28.10.2023 23:09:28InfoXDSL
VDSL connectivity is up port 1
28.10.2023 23:08:59WarningDHCPC
WAN DHCP client (1) stopped
28.10.2023 23:08:58InfoXDSL
VDSL connectivity is down port 1
28.10.2023 23:05:59ErrorDNS
DNS name resolution failure (_7001._https.appdeum.talktalk.co.uk)
28.10.2023 23:04:57ErrorDNS
54 REPLIES 54
Message 1 of 55
Hi AnnieMin,
I'm really sorry for the delay. Have you been able to connect since your last post or do you still need help with this?
Message 2 of 55
internet is down, all looks normal but no connection.
Message 3 of 55
Good afternoon,
I'm glad to hear that the stability has improved. I've not made any changes, however if it hasn't dropped since Friday then it may have been related to the previous outage which the team were working to resolve earlier in the day. Hopefully the connection will now remain stable but please let us know if anything does change.
Message 4 of 55
It has being stable since last dropouts, I saw the gateway IP changed and DHCP allocated another IP for me when reconnected, I assumed you've done something on your side that fix the problem.
Thank you
Min
Message 5 of 55
Morning AnnieMin,
I'm really sorry for the delay. Is your connection still dropping since your last post?
Message 6 of 55
Now coming back, the disconnection lasted for 5 minutes, during the time the indicator light is white, and the router shows it is well connected, but in fact unable to connect internet.
Attempting to ping the gateway IP or DNS IP results in a time-out.
This issue has occurred at least four times today so far.
Is the talktalk side outage still there?
Message 7 of 55
Down again now.
 from router it seems all right, light is white, but no internet connection... use hotspot to post this msg.
.Seems good butSeems good but
Message 8 of 55
down for 2 minutes this time, now it is up, the light keeps on white. annoying
Message 9 of 55
oh no.... the connection is down again
Message 10 of 55
Thanks for the update. I've just re-checked for an update and can see that this outage has now been resolved.
Message 11 of 55
the speed is also OK now at 74Mbps.
Message 12 of 55
Thank you for the update, the internet is coming back now.
I just went downstairs to ground floor to see if anybody was touching the exchange, but nobody was there.
Message 13 of 55
Hi again,
Update - This may be related to an outage which our team are looking into. I'll post back as soon as I know more.
Message 14 of 55
I'm really sorry to hear this. I've re-run the line test now which is clear and I can see 1 re-connection in the last 8 days. Are you still seeing the amber light on the router now? Is the voice service ok, do you have a dial tone?
Message 15 of 55
I just want to report the faulty coming back again.
The internet connection is totally cut off  right now..... the router's light shows solid amber,  restart the router already but not coming back.
please help.
Message 16 of 55
No problem, please let us know how you get on 🙂
Message 17 of 55
Thank you for your advise I would like to try if I have some free time .
I was told the root cause is a physical issue at the exchange inside the building, Openreach is planning to replace something at exchange,
but this would not proceed until a third party completes some repair works on the building.
Message 18 of 55
Hi again,
Thank you for the update. I've had a look at your connection stats now and the sync speed looks ok. Could you try powering down the router for a full 30 minutes and then retest the speed again please as this will reset the current session and can often increase the throughput speed.
Please let us know how you get on 🙂
Message 19 of 55
Good morning,
The connection has remained stable for over 5 days since the Openreach visit, which is positive news. However, the speed remains low, with the download speed (DS) under 40Mbps, despite the router saying 80Mbps, which is not reflective of the actual speed.
According to the Openreach engineer's comments, resolving this issue might take a considerable long time.
Kind regard
not realnot realonly half speedonly half speed
Message 20 of 55
Morning Annie,
How are you getting on?
