New router problem
Mike35
Message 5 of 5
Switched over to talktalk fibre 35 and set up went ok, working fine. BUT, 4 days in and returned home to find internet had dropped out (flashing amber light only).
Switched off, waited 20 + minutes and restarted. Amber light flashes continously no white light at any stage.
4 REPLIES 4
Message 1 of 5
Morning Mike,
I'm glad to hear this and thanks for letting us know 🙂
Message 2 of 5
Problem now resolved.
Line fault (x2) found by openreach engineer and rectified.
I'm impressed at the speed this problem was sorted, many thanks.
Message 3 of 5
  • Name
  • Telephone number
  • Alternative contact number
Message 4 of 5
I assume that this is the Sagemcom FAST 5364 router? What happens if you temporarily move the router with a new microfilter to the test socket behind the master socket's removable faceplate (if you have that type)?
