No Broadband connection since 24 May
Karen2022
Message 16 of 16
Off and on connection over the last few days.  From around 6pm yesterday (24 May)  the broadband connection stopped entirely.  Telephone working fine.
15 REPLIES 15
Message 1 of 16
Karen2022
Message 2 of 16
Thank you
Message 3 of 16
No problem, if it doesn't resolve the problem then we'll probably need to arrange an engineer visit, but hopefully it will
Karen2022
Message 4 of 16
Thank you.  Hope that fixes the problem, as I work from home too and need a connection.
Message 5 of 16
I've ordered the router, it should be with you within a couple of days
Karen2022
Message 6 of 16
Yes, that would be good.
Message 7 of 16
Line test is passing so I think we should try another router, would you like me to send on to test with?
Karen2022
Message 8 of 16
No, the previous router we had stopped working and you replaced it with the current one.
Message 9 of 16
Do you have another router that you can test with?
Karen2022
Message 10 of 16
Plugged into the telephone socket - yes
Router switched on - no
Checked this morning around 8:30am to see if the connection was back, but it was not, so I switched off the router.  No point in having it switched on, if there is no connection.
Message 11 of 16
OK thanks, was it switched on and connected to the telephone socket when you left home this morning?
Karen2022
Message 12 of 16
Hello Chris, I am not in same location as my router.  I am using a broadband connection at my place of work.
Chris-TalkTalk
Message 13 of 16
Hi Karen,
Thanks for updating your profile. Could you just confirm that your router is currently switched on and connected to your telephone socket
Karen2022
Message 14 of 16
Profile updated, as requested
Message 15 of 16
  • Name
  • Telephone number
  • Alternative contact number
