Remote desktop connection
on 13-06-2022 01:42 PM
Message 17 of 17
I'm not able to connect to my work remote desktop. Keeps connecting, then disconnecting. Any suggestions?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
16 REPLIES 16
on 20-06-2022 06:37 AM
Message 1 of 17
Hi Liz
Thank you 🙂
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 18-06-2022 10:48 AM
Message 2 of 17
Hi Debbie, just to let you know I’ve returned my old router this morning so should be with you early next week.
Kind regards
Liz
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 17-06-2022 06:36 PM
Message 3 of 17
Thanks Debbie, you too
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 17-06-2022 02:47 PM
Message 4 of 17
Hi Liz
Thank you 🙂
If you do experience any further issues then please let us know.
Have a lovely weekend.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 17-06-2022 02:43 PM
Message 5 of 17
Hi Debbie, survey completed and thanks very much again for your help.
kind regards
Liz
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 17-06-2022 06:54 AM
Message 6 of 17
Hi lizzieg1
I'm so glad to hear this 🙂
I have also sent you a Private Message with a short survey for our Community Team.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 16-06-2022 06:23 PM
Message 7 of 17
Hi Debbie, router arrived today and I’m now up and running and able to connect, no more stress!! Thanks very much for your help.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 14-06-2022 09:07 AM
Message 8 of 17
Hi lizzieg1
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 14-06-2022 09:03 AM
Message 9 of 17
Yes, thank you
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 14-06-2022 06:35 AM
Message 10 of 17
Hi lizzieg1
Ok thanks for testing this. I will need to send you a router for testing, are you happy for me to arrange this?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 13-06-2022 05:34 PM
Message 11 of 17
I’ve tried factory reset and that hasn’t worked. I keep getting message “the remote resource can’t be reached. Check your connection and try again or ask your network administrator for help”
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 13-06-2022 02:31 PM
Message 12 of 17
Hi lizzieg1
Ok, please can you factory reset the router using the pin hole reset for ten seconds and then try and connect again?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 13-06-2022 02:29 PM
Message 13 of 17
Yes the connection works okay apart from this. I have had my laptop tested by our IT department and been told that all settings are okay
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 13-06-2022 01:53 PM
Message 14 of 17
Hi lizzieg1
Thank you. I've just checked and your router should work ok with VPN.
Are you only experiencing this issue when using VPN, is the connection working ok apart from this?
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 13-06-2022 01:50 PM
Message 15 of 17
I believe it is a VPN and I've added my details to my profile. Thanks
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on 13-06-2022 01:44 PM
Message 16 of 17
Hi lizzieg1
Just to confirm, is this a VPN client?
Please can you add your name and TalkTalk landline number to your Community Profile, I can then take a look at this for you.
Show option menu
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
