WORK VPN ACCESS BLOCKED
Banjo27
Message 6 of 6
Hi everyone,
Similar to this post: https://community.talktalk.co.uk/t5/Fibre/Work-VPN-access-blocked-with-new-TalkTalk-fibre/td-p/28777...
and this: https://community.talktalk.co.uk/t5/Broadband/VPN-stopped-working-with-Sagemcom-SG4K100136/m-p/28803...
Been using this PC and Router combination to access my companies VPN for a long time working from home. Seems to have stopped working in the last 4/5 days. VPN is standard profile through Windows. Other TalkTalk customers in my company seem to be having the same issue.
I connected my PC to my mobile phone's hotspot using mobile data and there was no issue accessing the VPN.
TalkTalk Wi-Fi Hub
Hardware version: FAST5364 3.00
Software version: SG4K100136
It appears that a small change in the Firmware is required to re-allow VPN connections.
Banjo
Banjo
5 REPLIES 5
Message 1 of 6
Hi Banjo27
I'm so glad to hear that this is now working. I will feed this back.
Banjo27
Message 2 of 6
Hi Debbie,
All fixed thank you.
Could you please make the Telephone team aware of this fault as I spend ~30 minutes chatting to one of the operatives and he had no idea this was a problem and no idea how to fix it!
Thanks again
Banjo
Message 3 of 6
Hi Banjo27
All updated 🙂 Please can you retest and let us know how you get on.
Banjo27
Message 4 of 6
Ready to go right now Debbie.
Thanks for quick response.
Banjo
Message 5 of 6
Hi Banjo27
Apologies for this. I will need to make a change to your firmware. When would be the best time to do this?
We advise to leave the router switched on without being rebooted whilst the FW is being updated. This should take no longer than 15 minutes.
Anonymous User
