WiFi showing as ‘Connected’ but no devices loading
Lesson7
Message 16 of 16
Hi there,
All of my devices (iPhone, laptop, Smart TV) are showing as connecting to home broadband but nothing is loading. This has been the case for about 36 hours now.
A Broadband Connection Test indicates no known problems, but I’m unable to connect to carry out a Speed Test. I’m unable to check Network Service Status.
I’ve tried:
 - Rebooting the router
 - Using the Ethernet cable (which says there’s an issue with the DNS Server) with a laptop
- Using the Test connection
- Forgetting the Network on devices and adding again
 - Clearing browser cookies
 - Turning the tv off to ensure there’s no interference
- Having a bot explain what WiFi is to me for about two hours
Any help would be great
Thank you
15 REPLIES 15
Message 1 of 16
Hi Lesson7
How are you getting on?
pattisd01
Message 2 of 16
Hey there,
Only responding as I have seen similar issues - though mine have been intermittent and only over a period of minutes at a time.
I noted my issues appeared to be regarding DNS.
So I manually added DNS settings in the router config and used Googles Public DNS servers (primary 8.8.8.8 and secondary 8.8.4.4).
That has helped. I see less DNS issues and the browser pages load more than they fail.
So could be worth you trying the same approach.
Cheers,
Dave
Message 3 of 16
Hi Lesson7
No problem, please let us know how you get on.
Lesson7
Message 4 of 16
Thanks both!
Message 5 of 16
Hi Lesson7
Lesson7
Message 6 of 16
Hi Michelle,
 Yes please - that would be great, thank you!
Message 7 of 16
Ok thanks for confirming. As the line test is clear, would you like us to send a replacement router for testing purposes to rule this out? We would also send a router returns bag so that one of the routers can be returned.
Lesson7
Message 8 of 16
Hi Michelle,
  Thanks for your message! I’m afraid I don’t
Message 9 of 16
Do you have an alternative router that you could test with please?
Lesson7
Message 10 of 16
Hi Debbie - yes I’ve done that
Message 11 of 16
Hi Lesson7
Did you complete a factory reset (pin hole reset)
Lesson7
Message 12 of 16
Hi Debbie,
 Thanks for your message - please note I’ve also tried all of the recommended Troubleshooting tips as per my original message.
 Mobile devices are showing as connected to WiFi but then pages aren’t loading.
 Laptops are showing as connected to the network but ‘No internet access’.
 Troubleshooting internet connections through the laptop reports a DNS Server error.
Thanks for your help
Message 13 of 16
Hi Lesson7
Thank you for updating your Community Profile.
Please can you factory reset the router using the pin hole reset for ten seconds and then retest?
Lesson7
Message 14 of 16
Thank you Debbie - I’ve updated my info!
Message 15 of 16
Hi Lesson7
Please can you update your Community Profile to include your name and TalkTalk landline number, I can then take a look at this for you.
