on 16-02-2026 07:04 PM
Hi TalkTalk community (and any staff monitoring),
I'm at my wits' end and hoping for some real help or escalation here, as live chat support has been incredibly frustrating.
My setup and issue:
Support experience (just over 2 hours in chat so far):
Has anyone with the Sagemcom FAST5364-3 T8 (or similar older models) had the same all-devices-dropping-at-once issue with lots of IoT/smart devices, and successfully got a replacement (e.g., newer Wi-Fi 6 model like Wi-Fi Hub 3 or eero series that handles 75+ devices better, tri-band, more memory/processing)? Tips on forcing escalation, getting past "not faulty" responses, or what to say next? Thanks in advance—this needs sorting before I have to go formal complaint or consider switching providers. I'm sure a replacement newer router would fix the issue?
Appreciate any advice!
on 17-02-2026 03:08 PM
Hi there @KeithFrench, thank you very much for the help it's appreciated.
17-02-2026 02:46 PM - edited 17-02-2026 02:46 PM
Sorry for the delay, I have been very busy all morning.
This sounds to me like WiFi interference peaking at the time when these devices disconnect. Wi-Fi interference (nothing to do with electrical interference) can cause:-
This can affect one or more devices. This can also lead to a permanent reduction in the speed of one or more devices. No ISP can be responsible for your local environment; this is mainly a byproduct of the popularity of Wi-Fi.
Generally speaking, the 2.4GHz band suffers far more from Wi-Fi interference than the much faster 5GHz band. However, the 2.4GHz band has a longer range than the 5GHz band and can penetrate walls better. This may very well change depending on your local area.
In other words, I offer a free, impartial analysis of your Wi-Fi network and will try to help you optimise your Wi-Fi connection. The next stage involves my sending out a guide to help you get important diagnostic information for me. I will then analyse these results for you and recommend changes to your router configuration, if required.
on 17-02-2026 07:02 AM
@fr8ys thank you for the support.
on 16-02-2026 09:13 PM
Probably is as it's gone 9pm, knocking off time!
on 16-02-2026 08:56 PM
4 hours on chat with customer support..... shouldn't there be a siren going off somewhere?
16-02-2026 07:13 PM - edited 16-02-2026 07:51 PM
As you've posted on the fibre board, I assume you have Full Fibre, I'm afraid you will have to phone the fibre team as staff here do not have access to the full fibre systems.
Try phoning 0345 172 0088
Opening Hours can be found here - https://community.talktalk.co.uk/t5/Articles/How-to-contact-TalkTalk-Broadband/ta-p/2230529#
I note you are bitmining. As you state this is high demand. Perhaps this may be causing issues.
Having said you really need to phone for a resolution I'll ask a fellow CS @KeithFrench if he has any insight, as he is our resident router experts.
