installation
fakesnake
Message 3 of 3
I have installed my new router according to your instructions and all appears to be fine except I do not get a solid blue light at the base but a solid white light. Is this OK?
Message 1 of 3
Hi there @fakesnake, if it is white and working just fine there is no issue unless the light changes as @ferguson mentioned, should you encounter issues please do let us know.
Message 2 of 3
Bluey white. If it's working it must be OK. Orange indicates an issue.
